Update file properties without opening application
prakash.muthu
prakash.muthu
Hi, Looking for an option to update file properties without opening Revit application.
For example,
filepropsetter.exe revit -path <path of rvt> -propname <string> -propvalue <string>
The API will be added in filepropsetter.exe to query and update file properties. This will be used to store custom information in file.
Mohamed_Arshad
Hi @prakash.muthu
   Kindly check below links for additional reference.
Reference Link
https://jeremytammik.github.io/tbc/a/1407_read_rvt_without_revit.html
https://forums.autodesk.com/t5/revit-api-forum/accessing-revit-data-without-open-revit/td-p/6217928
Hope this will Helps  🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
prakash.muthu
We are looking for write and read operations in file. Exploring options to set and get few properties data.
