Update a 2014 solution to 2016...cant solve the error
Johan_Ekstrom
Johan_Ekstrom
Hey guys
A bit new to Revit API but i've got a working 2014-version which i am tryin to upgrade to 2016.
The updated parts are were the old code is changed to comment. Took a while to figure out the SelElementSet part... but when I update the two rows of code which are obsolete, I get a new error regarding the Insert.
If i remove the new code and reset the old (In comment) the Insert part is fine but the SelElementSet is errored.
How do i solve this...?
Any ideas, anythin obvious i am missing?
Type x and y with every move in AutoCad and no one bats an eye...but use coordinates in Revit and everybody loses their mind.
Hey! Do you want to Insert the Id of the Selected Element like this ?
ICollection<ElementId> selElements = uiDoc.Selection.GetElementIds();
                foreach (Room r in new FilteredElementCollector(_doc, _doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_Rooms))
                    try
                        if (str != "" && str2 == "" && str3 == "")
                            if (r.LookupParameter("Number").AsString().ToLower().Contains(str.ToLower()))
                                    selElements.Add(r.Id);
Johan_Ekstrom
You are a genius!
I was picking in the Add-part instead of Insert but i didn't figure out the ID part.
Thank you for your help, very kind of you. Now the application runs fine 🙂
rvtquestions
Hi @Johan_Ekstrom & @Anonymous
How would you edit the portion of code to work from:
Obtaining Element IDs:
to prompting the user via rectangle?
uiDoc.Selection.PickElementsByRectangle
replacing the line with that results in an error. Any thoughts? Thank you!
