Hi fellow Revit Users,
I work in the pre-cast industry and have very large live models I need to edit. To do this effectively, I select each element I need to edit and create a section box around it. If I need to cut through the part I am working on, I simply move the section box slider and then edit what I need to.
Here's the problem I hope someone can fix or educate me on:
Once I am done editing the internals of my selection, instead of moving the section box back to its original state, I would like to have the ability to undo my changes to the section box, without undoing the changes (Actions) to the part I am working on.
I understand the Revit architecture that "3D views" can be saved but this is a relatively inefficient process as there would literally be 1000+ 3D views that would have to be generated.
Any help you could give me would be great!
Thank you
Solved by bhprest. Go to Solution.
Hi there-
this is definitely possible via the API. Exactly how it's implemented is up to you. A rough process would be as follows:
Hope this helps!
Thanks for your help!
I will look into it.
If anyone else has other suggestions I would be interested in hearing them as well!
