Unchecked Make Plan View by default
By selecting the Level command on the ribbon men, Revit switches to Place Level options, where among other options, there is the Make Plan View, which is checked by default (see attached image).
I would like to know if there is a possibility to change somehow this behavior, so that the default for Make Plan View to be unchecked.
Thanks for your time,
Buddy
As far as i know, you can not change the Revit interface or default behaviour. you can only add new ribbon tabs, commands.
Thanks for the answer.
