It works with .bmp, .jpeg, .jpg and .png, but not with .tif files.
Code to reproduce :
UIApplication.DoDragDrop(new List<string> { "C:\Temp\Test.tif" });
It works if I insert the file with the dedicated command.
Solved by jeremytammik. Go to Solution.
Importing works fine, but dragging and dropping a tif doesn't. (When using the standard interface.)
Tested in Revit 2014 and 2017. Got 'Failed to open document' error in 2014!!! No error shown in 2017.
Sounds like a bug to me.
Cheers,
-Matt
Dear Maxence and Matt, Ma^2,
Thank you both very much for your report and verification.
I logged the issue REVIT-105328 [drag and drop fails with TIF] with our development team for this on your behalf as it requires further exploration and possibly a modification to our software. Please make a note of this number for future reference.
You are welcome to request an update on the status of this issue or to provide additional information on it at any time quoting this change request number.
This issue is important to me. What can I do to help?
This issue needs to be assessed by our engineering team, and prioritised against all of the other outstanding change requests. Any information that you can provide to influence this assessment will help. Please provide the following where possible:
This information is extremely important. Our engineering team have limited resources, and so must focus their efforts on the highest impact items. We do understand that this will cause you delays and affect your development planning, and we appreciate your cooperation and patience.
I hope this helps.
Best regards,
Jeremy
