Twinmotion plugin not opening.
1990483XLA4
1990483XLA4
Community Visitor
Community Visitor
why is the Twinmotion plugin not working  when I click on it from Revit, it's not even giving any sign of loading I click and nothing happens, I tried deleting and installing Twinmotion but it didn't work, I am using Revit 2025.2
jeremy_tammik
Are you programming anything yourself using the Revit API? If not, sorry, cannot help here.
Please note that this discussion forum is dedicated to programming Revit using the Revit API. Afaict from your query, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. In that case, you will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
