Turn Ribbons On & Off
michellem
michellem
Hello Everyone;
Is it possible to create a button that would list all available ribbons (built-in and add-ins) along with a checkbox to turn ribbons on or off?
I am thinking of something that would look like the User Interface pulldown:
Ideally, I would like it on the quick access toolbar.
Or maybe someone has already made something like this?
Any help, as always, is appreciated.
Michelle
Accepted solutions (3)
moturi.magati.george
Hi @michellem,
Not sure if this is what you are looking for but Jeremmy's Blog actually talks about this. It will be interesting to see the thoughts of others too.
https://thebuildingcoder.typepad.com/blog/2013/07/dynamically-hide-and-display-a-ribbon-panel.html
  Moturi George,     Developer Advocacy and Support,  ADN Open
michellem
Hello Moturi;
Not quite... I believe a Ribbon Panel is the green clouded item and what I want to turn off (not visible) is the red clouded item. For built-in ribbon tabs, there is way via the Revit Options dialog.
From Jeremy's blog and other postings, I think the answer might lie in these two DLLs. However I can not find much info about them...
  • AdWindows.dll
  • UIFramework.dll
Does anyone have any info?
Sincerely;
Michelle
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @michellem ,
Are you looking for this?
Autodesk.Windows.RibbonControl ribbon = Autodesk.Windows.ComponentManager.Ribbon;
foreach (Autodesk.Windows.RibbonTab tab in ribbon.Tabs)
   if (tab.Title.Contains("Modify"))
      tab.IsVisible = false;
Before
After
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
michellem
Hello Naveen;
That is exactly what I was looking for.
Here is a code snippet in Python:
clr.AddReference('AdWindows')
import Autodesk.Windows as adWin
ribbon = adWin.ComponentManager.Ribbon
for x in ribbon.Tabs:
  if x.Title.Contains ("JOTools"):
    x.IsVisible = True
Next task...Figure out if it is possible to get a drop down checkbox control into the Quick Access Toolbar.
Thanks much;
Michelle
