Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Trying to retrieve the DimensionType of a Dimension
5 REPLIES 5
Alexandra.Nelson
737 Views, 5 Replies
I'm trying to build a ZeroTouchNode with C# in Visual Studio that's input is a Dimension element and it's output is the DimensionType of that Dimension element. It seemed simple, but I'm having trouble returning the DimensionType element. Instead, the node is returning "Autodesk.Revit.DB.DimensionType". How do I retrieve the actual element? My code is included below. Thanks in advance for the help!
using System;
using System.Linq;
using System.Threading.Tasks;
using System.Text;
using Autodesk.DesignScript.Runtime;
using System.Collections.Generic;
using Autodesk.Revit.DB;
using RevitServices.Persistence;
namespace CustomNodes
    public class Dimensions
        private Dimensions()
        public static ElementType GetDimType(Revit.Elements.Element dimensions)
            Document doc = DocumentManager.Instance.CurrentDBDocument;
            Element UnwrappedElement = dimensions.InternalElement;
            ElementId id = UnwrappedElement.GetTypeId();
            ElementType dimType = doc.GetElement(id) as ElementType;
            return dimType;
5 REPLIES 5
You code looks perfectly fine to me.
Probably, there is a misunderstanding involved.
The DimensionType IS the actual element.
Maybe your target does not expect an Element instance at all, just the ElementId.
Therefore, you might be able to just return `id` and skip the call to `GetElement`.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you Jeremy. When I try to return the id, it returned the id of the dimension type, but not the dimension type element. Also, when I tried to return the element using the "Get Element" method and changed the return type to "Element" (as seen below) rather than "ElementType" as I had previously, it still gives me the same output.
using System;
using System.Linq;
using System.Text;
namespace theWorks
        public static Element GetDimType(Revit.Elements.Element dim)
            Element UnwrappedElement = dim.InternalElement;
            Element dimType = doc.GetElement(id) as Element;
            return dimType;
Well, if the DimensionType element is wrong, and the element id is wrong, then something else is hopefully right.
Unfortunately, I cannot imagine what, and you give no hint either.
In desperation, it might be worthwhile to read the documentation (of what, actually? is there any?) and find out what it is we are actually trying to achieve...
Jeremy Tammik
The Building Coder
FAIR59
in reply to: Alexandra.Nelson
You can not directly return a Revit class. You need to "wrap" into a Dynamo wrapper class.
see https://forum.dynamobim.com/t/become-a-dynamo-zero-touch-c-node-developer-in-75-minutes/28007
and download the handout
Alexandra.Nelson
in reply to: FAIR59
Thank you for your help and for sharing the link with me. I worked through the concepts in that handout and got it working.
Here's the working script :
using Revit.Elements;
namespace theWorks
        private Dimensions() { }
        public static Revit.Elements.Element GetDimType(Revit.Elements.Element dimension)
            Autodesk.Revit.DB.Element UnwrappedElement = dimension.InternalElement;
            return dimType.ToDSType(false);
Autodesk DevCon in Munich May 28-29th
Rail Community
