Trouble with Windows Forms, in method "SetCompatibleTextRenderingDefault"
Hi everyone. I'm trying to make an add-in which uses a windows form. For that, I copied the code used in the "Getting Started" walkthrough in the Revit API guide, and modifided it. I'm always getting the same error message: "SetCompatibleTextRenderingDefault must be called before the first IWin32Window object is created in the application.". Here is the code that I've tried to use.
CsAddPanel.cs:
using System;using System.Reflection;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
namespace Walkthrough
   /// <remarks>
   /// This application's main class. The class must be Public.
   /// </remarks>
   public class CsAddPanel : IExternalApplication
      // Both OnStartup and OnShutdown must be implemented as public method
      public Result OnStartup(UIControlledApplication application)
      	// Add a new ribbon panel
         RibbonPanel ribbonPanel = application.CreateRibbonPanel("NewRibbonPanel");
         // Create a push button to trigger a command add it to the ribbon panel.
         string thisAssemblyPath = Assembly.GetExecutingAssembly().Location;
         PushButtonData buttonData = new PushButtonData("cmdHelloWorld",
            "Hello World", thisAssemblyPath, "Walkthrough.HelloWorld");
         PushButton pushButton = ribbonPanel.AddItem(buttonData) as PushButton;
         // Optionally, other properties may be assigned to the button
         // a) tool-tip
         pushButton.ToolTip = "Say hello to the entire world.";
         // b) large bitmap
         Uri uriImage = new Uri(@"C:\globe.png");
         BitmapImage largeImage = new BitmapImage(uriImage);
         pushButton.LargeImage = largeImage;
         return Result.Succeeded;
      public Result OnShutdown(UIControlledApplication application)
         // nothing to clean up in this simple case
   /// <remarks>
   /// The "HelloWorld" external command. The class must be Public.
   /// </remarks>
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
   public class HelloWorld : IExternalCommand
   	// The main Execute method (inherited from IExternalCommand) must be public
      public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit,
          ref string message, ElementSet elements)
   			Form1 form1 = new Form1();
      		Application.EnableVisualStyles();
			Application.SetCompatibleTextRenderingDefault(false);
			form1.ShowDialog();
         //TaskDialog.Show("Revit", "Hello World");
         return Autodesk.Revit.UI.Result.Succeeded;
Here's a screenshot of the form that I'm trying to use (and of the SharpDevelop views):
Finally, here's a screenshot of the error message in revit:
Thank you
Leandro
RPTHOMAS108
I'm not familiar with 'Application.SetCompatibleTextRenderingDefault(false)' it appears to be a legacy setting and is probably not required (since false is apparently the default from 2.0 onwards). The error is asking you to put the line:
before the line:
You should probably do the same with Application.EnableVisualStyles.
I've tried it, but it didn't worked.
RPTHOMAS108
Take the line out completely you'll likely notice no difference from the intended functionality of the sample.
Reading further I believe the call is only valid for standalone apps. If the app is hosted by another then there is little chance a Window hasn't already been created before you call this function.
It worked fine! Thanks a lot.
