TransmissionData causing error for Local Revit file.
Hi Everyone,
I tried to using TransmissionData to unload all the Revit link before open it. But it seems like when I apply it for a Local Revit file, it make the local file disconnected with the central file and Revit ask to save it as Central file.
So if anyone have some experience with this issue, please help me :).
Thank you so much
 BasicFileInfo fileInfo = BasicFileInfo.Extract(s);
                if(fileInfo.IsCentral==false)
                    ModelPath mp = ModelPathUtils.ConvertUserVisiblePathToModelPath(@s);
                    TransmissionData transmis = TransmissionData.ReadTransmissionData(mp);
                    ICollection<ElementId> linkID = transmis.GetAllExternalFileReferenceIds();
                    foreach (ElementId elementId in linkID)
                        ExternalFileReference extRef = transmis.GetLastSavedReferenceData(elementId);
                        ModelPath linkpath = extRef.GetPath();
                        if (extRef.ExternalFileReferenceType == ExternalFileReferenceType.RevitLink
                            && ModelPathUtils.ConvertModelPathToUserVisiblePath(linkpath).ToString().Contains(Path.GetFileNameWithoutExtension(s)) == false
                            //TaskDialog.Show("Revit link", ModelPathUtils.ConvertModelPathToUserVisiblePath(linkpath).ToString());
                            transmis.SetDesiredReferenceData(elementId, linkpath, extRef.PathType, false);
                    transmis.IsTransmitted = true;
                    TransmissionData.WriteTransmissionData(mp, transmis);
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
If you open a transmitted Revit model that is workshared, you are prompted to save the model locally or to Central.
To achieve this you can use TransmittedModelOption
TransmittedModelOptions Enumeration
You can use any one of the below modeloptions
TransmittedModelOptions TMO = TransmittedModelOptions.SaveAsNewCentral;
                TransmittedModelOptions TMO = TransmittedModelOptions.CancelOperation;
                TransmittedModelOptions TMO = TransmittedModelOptions.KeepAsTransmitted;
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Hi Naveen,
Thank you for your suggestion. But I still don't know how to implement TransmittedModelOptions enum into my code. Could you please help me with more details how to implement this?
Thank you so much Smiley Very Happy
Best Regards,
Cherry Truong
I have the same problem. Can anyone help?
