Transformation rules for familyinstance
dirk.neethling
dirk.neethling
I am trying to transform a familyinstance. It either does not respond at all to
ElementTransformUtils.RotateElement
ElementTransformUtils.MoveElement
or responds illogically. When I apply the abovementioned methods to an adaptive instance obtained from,
AdaptiveComponentInstanceUtils.CreateAdaptiveComponentInstance
everything reacts logically. However in the case of a familyinstance, it seems that other rules apply. Which methods can I use to obtain Rotation and Translation of a familyinstance? Should I use
fi.Location.Rotate
fi.Location.Move
instead?
dirk
ElementTransformUtils.MoveElement  is use to displace a element from one location to another location.
You can use this  as below
1st :   Lp = FamilyInstance Location Point.
     You want to move at new Point that is newPosition;
after that do it like.
    XYZ newposition=new XYZ(1,1,1);
   XYZ oldPosition=Lp;
   XYZ MovePosition=null;
   MovePosition= newposition- oldPosition
   ElementTransformUtils.MoveElement(Doc, Elemnetid, MovePosition)
i hope this will work fine.
