Transfer project Parameter
Hi have a rvt file with a Project parameter named "TOTBarre" and associated to rebar
can i transfer it to another file using API?
I use this code for transfer rebartype, but for parameter?
  Dim list2 As New List(Of RebarBarType)(Enumerable.Cast(Of RebarBarType)(New FilteredElementCollector(docTemplate).OfClass(GetType(RebarBarType))))
                Dim listID2 As IList(Of ElementId) = New List(Of ElementId)
                If (list2.Count = 0) Then
                    MsgBox("Le annotazioni per armature sono state cancellate dal file prototipo!",, "ED-RebDet2D - Caricamento Standad di Progetto")
                    t.RollBack()
                    GoTo a300
                Dim type1 As RebarBarType
                For Each type1 In list2
                    listID2.Add(type1.Id)
                Next
                ElementTransformUtils.CopyElements(docTemplate, listID2, _doc, Nothing, New CopyPasteOptions)
Stefano
matthew_taylor
Hi @Anonymous,
The way to test this is to do the process manually.
  1. Find out the elementId of thing you want to copy
  2. Select it using Manage > Inquiry > Select by ID
  3. 'Copy to Clipboard'
  4. Go to new project
  5. 'Paste from Clipboard'
Check if warnings/errors happen, then check results.
In my experience, this process is a facsimile.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
