Transaction inside IFailuresPreprocessor
newbieng
newbieng
Hi everybody,
my issue is referred to my previous post cannotMakeTypeError .
I'm using now the BuiltInFailures.FamilyFailures.CannotMakeType and I managed to avoid the message error on the screen, forcing the "failure" transaction to ProceedWithCommit; here's my succesful code for that:
public class TypeErrorSwallower : IFailuresPreprocessor
	public FailureProcessingResult PreprocessFailures(FailuresAccessor a)
		IList<FailureMessageAccessor> failures = a.GetFailureMessages();
		foreach( FailureMessageAccessor f in failures )
		    FailureDefinitionId id = f.GetFailureDefinitionId();
		    if( BuiltInFailures.FamilyFailures.CannotMakeTypeCB == id )
		    	return FailureProcessingResult.ProceedWithCommit;
		 return FailureProcessingResult.Continue;
What I'm asking now, is if it's possible to make changes to the model when it goes into the PreprocessFailure: suppose that I have a transaction setting the L parameter and a value is causing the failure because it can't make any type, I would change the value of that parameter and then go on with the rest of the code...
I tried to insert a new transaction within the FailurePreprocessor but when I debug the code I found that the Set() causes a new error and no change is executed, I've attached a very simple file with a test-family (made only to reproduce the error) and my code: someone can help me with this?
Is it possible set a parameter to a different value when it comes to the preprocessFailure?
Thanks in advance
RPTHOMAS108
Not possible. You have to commit transaction and then decide what to do about failure.
During failure processing you may roll back transaction, pick a resolution predefined for the type of failure encountered or remove warnings. The process then repeats.
