[transaction] difference
Joris.vd.Meulen
Joris.vd.Meulen
What is the difference between:
//used here for example (https://www.revitapidocs.com/2017/31b73d46-7d67-5dbb-4dad-80aa597c9afc.htm)
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.ReadOnly)]
//used in my coding
[Transaction(TransactionMode.Manual)]
love python coding
jeremytammik
Try it out!
Always try out everything!
Never trust anybody except your own code!
Still, if you insist:
If you set your transaction mode to read-only, Revit will throw an exception if you try to open a transaction.
That guarantees that your add-in will under no circumstances be able to modify any documents.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Joris.vd.Meulen
Hi @jeremytammik ,
Fiddling with C# that is what I'm doing all the time. Smiley Very Happy
So if an addin has no intention of altering the model itself, the TransactionMode should always be ReadOnly.
Because
1. safer
2. clear coding / understandable
3. faster (???) (For example: I can imagine that selection addin in ReadOnly could be faster than Manual selecting 100k elements?)
love python coding
jeremytammik
Dear Joris,
Thank you for your update.
> So, if an add-in has no intention of altering the model itself, the TransactionMode should always be ReadOnly.
Yes, absolutely!
> safer
Yes.
Yes.
Unknown. Please try it out and let us know.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
