Trailing Window
Trailing Window
ahmad.mahid
Observer Observer
Trailing Window
ahmad.mahid
Observer
Observer
When moving around the dockable windows, they leave a grey outline trail making it hard to follow where the snap-in point is. I have already attempted toggling hardware acceleration and updating my drivers. I have also tried toggling the "show windows content while dragging" setting and nothing has worked. I am on Windows 10, 1709.
jeremytammik
Dear Ahmad Mahid,
Thank you for your report.
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically, or just using the standard Revit user interface?
If you are not doing anything programmatically, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies. Thank you for your cooperation and understanding.
If you are doing it programmatically, please submit a minimal reproducible case with exact steps to reproduce the problem that I can share with the development team:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
