Torsion Tools GitHub Launch and basic Solution Overview!
TorsionTools
TorsionTools
I wanted to share my Autodesk Revit 2020 API Visual Studio Solution Template with Code Examples for Common Tools
The intent of the repository is to help provide REVIT API support and to share code examples and solutions for common issues or time consuming tasks in Revit. I will provide examples and tools of items as I have created and use them, and then other are free to manipulate them to fit how they need them to work, but without any expressed or implied warranty and/or guarantee of functionality or errors. I think this will be the best way to share some of the work I have done without having to create installers for every single tool or publishing everything to the Autodesk App Store.
GitHub: https://github.com/TorsionTools/R20
YouTube: https://youtu.be/3EVx9SzKJbk
jeremytammik
Wow, sounds great!
Thank you very much for sharing this!
There is a glitch in the GitHub URL. The correct one is given in the YouTube description text:
Jeremy Tammik
Developer Technical Services
The Building Coder
TorsionTools
Thanks @jeremytammik, is there any way to edit the post and fix the link?
jeremytammik
I tried occasionally and have not been able to do so myself so far.
Jeremy Tammik
The Building Coder
