Toposolid Texture Misalignment When Using Section Box
julius_svirskas
Message 1 of 1
julius_svirskas
Hi, The Revit 2025 version has new issues with textures on Toposolid. When the section box is turned on, the texture moves along with the section box boundary. The texture should be fixed based on the Toposolid material size and location offset, aligning with the original object's dimensions. Ideally, the texture's position should be determined by the original object rather than shifting according to the section box boundary.
I hope this issue is resolved in the 2026 version.🙂
Replies (0)
