This revit problem?
This revit problem?
This revit problem?
I made Revit add-in dll(called 'Test.dll')
In Test.dll project, i did add the Interop.ADOX.dll.
When i execute Test add-in in Revit 2013, an error occured(FileNotFoundException about Interop.ADOX.dll)
I tried to find this problem by debugging.
When i debugging,
Revit load only Test.dll, not load Interop.ADOX.dll
Is this revit problem?
arnostlobel
It is a coincidence that someone had asked the very same question just a short while ago. You can find my reply there, but in a nutshell: ADOX.dll is not for you to use. You can only reference two Revit assemblies from your external add-in - RevitAPI.DLL and RevitAPIUI.dll. They combined expose all the functionality Revit API has to offer to 3rd party developers.
Thank you
Arnošt Löbel
Autodesk Revit R&D
Arnošt Löbel
