This is Cell hole related topic
This is Cell hole related topic, there are array of cell-holes in one structural profile like Beam, Column etc.
While extending start point or end point of member, Cell Hole position / number of Cell Hole will change because of change in the dimensions of member. This will affect the actual location of Cell Hole.
Precisely I don’t want to change cell-hole position even after change in start point or end point.
So, how to control this cell hole position. Cell-hole applied as void in a family.
If having any solution kindly help me.
Your help appreciated & Welcome.
-RK.
jeremytammik
Duplicate of
https://forums.autodesk.com/t5/revit-api-forum/this-is-cell-hole-related-topic/m-p/7094712
Let's continue the discussion there instead.
Jeremy Tammik
Developer Technical Services
The Building Coder
