The Survey Point data of a linked model is not the same to when it is self-opened
bernardpttsang
bernardpttsang
I am currently using  FilteredElementCollector class & IsShared property to extract Survey Point data of linked models. However, the extracted Coordinates are different to what I found when I open the linked models. Why?
RPTHOMAS108
You'd have to explain some more i.e.
Are you extracting the location or a parameter value for such?
Different how?
Some sample code and empty project files (primary + link) may help also to demonstrate what you are encountering.
bernardpttsang
For example, I have 2 model files A & B
When I open the models, turn on PBP & SP, say, I may have these data:
A: PBP=100 ; SP=300
B: PBP=100 ; SP=300
But when I open A, then link B and using the coding to extract the survey point data, I got:
A: PBP=100 ; SP=300
B: PBP=100 ; SP=100
B is linked into A with Shared Coordinates, is that the reason?
