The path to load the Bundle file
dungthachbomay
dungthachbomay
Hello!
I am programming Revit API with C# and I am preparing to create a ribbon, I have a question as follows:
- Suppose I installed Revit on the "D" drive, will the "C: \ ProgramData \ Autodesk \ Applicationplugins" path exist?
- In case (maybe not happening) is my computer or customers intentionally without the "C" drive, "Autodesk \ Applicationplugins" lies in which path?
- Can someone help me!  Thank you very much
jeremy_tammik
You can determine details of the Revit installation from the registry. The Revit SDK includes a tool for that, the RevitAddinUtility. Furthermore, @ricaun  built and shared a replacement for that utility named Autodesk.PackageBuilder
ricaun
Revit basically search in the two folder for the ApplicationPlugins.
Current User - %AppData%/Autodesk/ApplicationPlugins
All Users    - %ProgramData%/Autodesk/ApplicationPlugins
The %ProgramData% usually is the C:\ProgramData\ and I guess the drive C is where the windows is installed.
In code would be something like:
private const string RevitApplicationPluginsFolder = "\\Autodesk\\ApplicationPlugins\\";
/// <summary>
/// Get AllUsers ApplicationPlugins Folder
/// </summary>
/// <returns></returns>
public static string GetAllUsersApplicationPluginsFolder()
    return Environment.GetFolderPath(Environment.SpecialFolder.CommonApplicationData) + RevitApplicationPluginsFolder;
/// <summary>
/// Get CurrentUser ApplicationPlugins Folder
/// </summary>
public static string GetCurrentUserApplicationPluginsFolder()
    return Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData) + RevitApplicationPluginsFolder;
The Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData) return the C:\ProgramData\ folder.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
