The icon of pushbutton is not displayed
choshQT24J
choshQT24J
I have tried several ways for setting image of pushbutton.
none of them worked. Is it a bug? ( revit2024)
var image = new BitmapImage(new Uri("pack://application:,,,/MyProject;component/Resources/icon128x128.png"));
PushButtonData buttonData = new(name, text, thisAssemblyPath, className);
buttonData.ToolTip = tooltip;
PushButton pushButton = ribbonPanel.AddItem(buttonData) as PushButton;
pushButton.LargeImage = image;
moturi.magati.george
Hi @choshQT24J,
Kindly try to add your icon to the resources first i.e., right click on your project, go to properties, go to Add Resource and select new image.
You can then try to use the code below:
Image img = Properties.Resources.icon128x128;
ImageSource imgsrc=GetImageSource(img);
PushButtonData btnData = new PushButtonData( name, text,thisAssemblyPath,thisAssemblyPath)
    ToolTip = tooltip,
    LongDescription = "",
    Image = imgSrc,
    LargeImage = imgSrc
PushButton pushButton = ribbonPanel.AddItem(btnData) as PushButton;
  Moturi George,     Developer Advocacy and Support,  ADN Open
choshQT24J
Is this the only proper way?
For the way I used,
I have set my icon into the resource.
And there is no compile error or running error.
My understanding is that my icon is set up correctly without any execution errors, but it just doesn't get displayed.
If I did not add it as a resource it would be an execution error.
Hi @choshQT24J,
You can also have a look at your icon resolution and resize it appropriately.
https://www.revitapidocs.com/2018/34d5d65e-d835-74ec-7c67-22b3b1c684f5.htm
https://www.revitapidocs.com/2018/558a403d-2002-10e9-30d8-c0160f5115dc.htm
choshQT24J
I have also tried to resize to 32x32. Not work.
And the link you provide said "If the image is larger it will be adjusted to fit the button".
Mohamed_Arshad
Hi @choshQT24J
Two things you have to update in Icon.
1. Icon Size (32x32 Pixels)
2. Icon Dpi to 96-100.
then it will fit in your button.
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
choshQT24J
Thanks Mohamed_Arshad! You save my life.
I did not know it also limit by dpi. So terrible implemention of the API!
