The height and width of the dimension text
SimonaQQ
SimonaQQ
I want to implement such a function. When dimension text overlaps, move one of the dimensions so that it no longer overlaps.
My idea is to calculate the rectangular border of the text through the position of the text and the width and height of the text, and then judge whether the rectangular borders intersect.
So how to calculate the width and height of dimension text?
Thank you.
DimensionDimensionDimentionType ParametersDimentionType Parameters
jeremy_tammik
Look at these two recent threads here in the forum:
jeremy_tammik
Did you solve it? I hope so! Shared the thread on the blog:
https://thebuildingcoder.typepad.com/blog/2022/01/detailed-2d-text-and-other-element-geometry.html#2
sonicer
problem is the Text Note have parameter width of text...but dimension text doesn't.
you need testing many situation for create some algorithm or use The coder solution 😉
