07:42 PM
Now I am using the function of Rendaring with Revit.
I found when I change the dimmer and color for one lamp, and the dimmer and color of the lamps with same type will be changed together.
Can I change the dimmer and color for each lamp when I use the Rendaring?
I think there is one method that I can copy and modify the lamp, but if I have so many lamps, it will be a heavy works.
Could you please give me some advice?
Thanks for you very much !
