Temporarily Disable Model Regeneration in the API
Hey. This is Old Post  where the topic of temporarily disabling model regeneration was discussed. This is relevant. Will such functionality be implemented?
jeremytammik
I am not aware of any such plans.
If this is important to you, I would suggest reopening the issue again,. or submitting a new one that gains enough support to be implemented.
Jeremy Tammik
Developer Technical Services
The Building Coder
 But this code works quickly with the number of species 200-300? This code also happens to BoundingBox and Outline? This Code
jeremytammik
Try it out, benchmark it, and let us know the result.
That speed has nothing to do with regeneration, though, because it is read-only, isn't it?
Jeremy Tammik
The Building Coder
