Tee Fitting with no right-angle
AnatolyCEL
Message 1 of 10
AnatolyCEL
I need to connect branch pipe to main pipe with Tee Fitting by API, like in the picture. Branch pipe must have angle 45 degrees to main pipe. When I try to do it, I have exception about too small or too large angle. So I have to make several steps:
  1. Create branch pipe perpendicular to main pipe
public static Pipe Create(
     Document document,
     ElementId systemTypeId,
     ElementId pipeTypeId,
     ElementId levelId,
     XYZ firstPoint,
     XYZ secondPoint
  1. Create Tee Fitting
public FamilyInstance NewTeeFitting(     Connector connector1,     Connector connector2,     Connectorconnector3)
  1. Disconnect branch pipe from this fitting
public void DisconnectFrom(     Connectorconnector)
  1. Rotate the branch pipe
public bool Rotate(     Line axis,     doubleangle)
  1. Connect again
public void ConnectTo(     Connectorconnector)
  1. Change symbol of the fitting 2 times to see effect at the draw
public FamilySymbol Symbol { get; set; }
Question: Is it possible to do it easier?
Thanks.
Replies (9)
Message 2 of 10
Aaron.Lu
Dear,
Did you do this:
1. Create branch pipe with the right angle.
2. call NewTeeFitting to create the fitting.
3. change fitting type.
Or
1. create branch pipe
2. rotate branch pipe
3. create fitting via NewTeeFitting
4. change fitting type
Or
Or
3. create fitting via NewFamilyInstance
4. call Connector.ConnectTo several times to connect fitting with pipes
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Message 3 of 10
AnatolyCEL
I do:
1. Create branch pipe with the right angle (if I try to create with 45 degrees, NewTeeFitting throws exception "too smal or too large angle")
3. Disconnect the branch pipe from the fitting (if rotate the pipe without disconnecting, commit transaction give the message and disconnect itself)
4. Rotate the branch pipe
5. Connect back the branch pipe to the fitting (connection is done, but is not visual effect in drawing)
6. To get the visual effect in drawing, change fitting type to any type different from required and change again back to required type.
It seems to long way, maybe it's possible easier?
Message 4 of 10
Aaron.Lu
We have an issue ticket for this:
REVIT-58630 NewTeeFitting method fails with 45 degree angle
So I think another way you can try is to call NewFamilyInstance to create the tee and rotate it then connect to each pipe.
Aaron Lu
Message 5 of 10
AnatolyCEL
Has the issue (REVIT-58630 NewTeeFitting method fails with 45 degree angle) resolved?
Anatoly.
Message 6 of 10
Aaron.Lu
Hi AnatolyCEL,
sorry, it has not yet been fixed. I'm afraid it might not be included in Revit 2017
Aaron Lu
Message 7 of 10
sniMD547
I was wondering if there is any progress regarding this matter. I am using Revit API 2018, and the problem still exists.
Kind regards
Message 8 of 10
Has this issue been fixed yet?
BTW is there a URL where I can monitor the progress of this issue (REVIT-58630)?
Message 9 of 10
carolina.machado
Message 10 of 10
Chuong.Ho
Oh my god, this is a problem has 8 year, may be need to hack it 😗
Chuong Ho
