TaskDialog.EnableMarqueeProgressBar
AdvancedBIMSystems
Message 1 of 10
AdvancedBIMSystems
I believe this was introduced into Revit 2020 API but can't find any examples of how to implement.
Any links / sample /  ideas would be much appreciated.
Replies (9)
Message 2 of 10
jeremytammik
Thank you for asking. Neither can I. I asked the development team for you.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 10
AdvancedBIMSystems
Thanks Jeremy, look forward to their response.
Cheers
Message 4 of 10
studio-a-int
@AdvancedBIMSystems  - was that method mentioned by ADSK
development team?
neither .NET or Revit API, shows that method available. Maybe I'm missing something.
Message 5 of 10
AdvancedBIMSystems
Message 6 of 10
RPTHOMAS108
A progress bar with an indeterminate state on a modal TaskDialog that has to be closed by the user:
Q) When is the progress finished?
A) When I select one of the TaskDialog options.
I always assumed it was intended to be more but not developed or internal use not intended to be exposed. It was documented in the 2012 API, back then they had a developer guide pdf and the full visual appearance was indicated:
http://help.autodesk.com/view/RVT/2019/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Appendices_API...
Message 7 of 10
AdvancedBIMSystems
I think it can still be useful for a user to have the choice to accept or cancel the result of a given function.
Cancel could be made to roll back the function + close the TaskDialog  & ok commit the result + close.
It's probably not appropriate for every situation if it does work that way.
Hope to get an answer soon anyway...
Message 8 of 10
AdvancedBIMSystems
I still can't find any info on this topic. Would be great to hear some feedback, thanks.
Message 9 of 10
jeremytammik
Please guys, learn to learn!
To do so efficiently, you often need to read the documentation and test things yourself.
By the way, rereading my first answer above, I note that this advice applies to me myself as well.
Sorry for not taking a closer look myself the first time around.
The documentation already says it all:
https://www.revitapidocs.com/2020/b3a3412b-1f70-f7a6-a97f-12c51eaff104.htm
Enables a marquee style progress bar to be displayed in the TaskDialog.
When true, the TaskDialog will display a progress bar that has an indeterminate start and stop. A progress bar is a window that an application can use to indicate the progress of a lengthy operation. It consists of a rectangle that is animated as an operation progresses. The animation continues until the TaskDialog is closed. The default value is false.
Here is some sample code:
  TaskDialog d = new TaskDialog( "Test Marquee" );
  d.MainContent = "Testing the EnableMarqueeProgressBar property";
  d.MainInstruction = "Click 'Close'";
  d.EnableMarqueeProgressBar = true;
  d.Show();
I attached a full solution.
It took a handful of minutes to put together and test.
Please do so yourself next time before asking questions like this.
It will save time for yourself, not to mention others.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 10 of 10
AdvancedBIMSystems
Thanks for your help Jeremy (& quirky response).
p.s. you saved me some time
