TaskDialog - color text
RECArchi
RECArchi
I want to color the text of the results I get from my plugin (green for right values - red for wrong values). Is it possible using Revit TaskDialogs? Or do I need to use WPF (textblock with green/red foreground) ?
Thank you in advance.
Sincerely.
aignatovich
Hi!
Autodesk.Revit.UI.TaskDialog has a limited support of a HTML in main and expanded content, for example, it supports hyperlinks. You can try it, but I'm pretty sure, you need to create your own UI using WPF or WinForms
Dear @jeremytammik and others,
may I draw your attention in this regard please. I'm going through the same problem, so instead posting another similar question , I am just bringing this one in front.
When the task dialogue box will be displayed as an output, I would like to change color or font size of particular line's  (so that the particular line become eye catching). I am currently working with stringbulider which does not contain any font variation. Is there any other simple way (except WinForms) to do the work?
jeremy_tammik
Thank you for reusing the question instead of raising a new one.
Thank you even more to Alexander for already answering it.
I fully concur with Alexander's statements above.
Best regards,
Jeremy
