Tag Walls through API
dgoff96
dgoff96
I have been trying this over and over again, and can’t seem to get it to work. I am working on a tool that should add wall tags to certain walls, however, I’m having trouble with the IndependentTag.Create() method. Below is my code (in python). I recycled this code from another tool that tags different element types and works just fine, so I’m pretty sure the syntax is correct:
families = DB.FilteredElementCollector(doc).OfCategory(DB.BuiltInCategory.OST_WallTags).OfClass(DB.FamilySymbol).ToElements()
    for fam in families:
        if fam.Family.Name == "MyTagName":
            tag = fam
            break
tag = DB.IndependentTag.Create(doc, tag.Id, view.Id, DB.Reference(wall), True, DB.TagOrientation.Horizontal, mid_point)
I keep getting this error:
Exception: The ElementId symId does not correspond to a FamilySymbol. I have checked that the "tag" element that is returned from my for loop is in fact a Family Symbol, so I'm not sure what I am doing wrong here. Any help would be greatly appreciated!
dgoff96
I wound up solving this myself. Somehow, the tag.Id was getting changed somewhere along the way (not sure how as I couldn't find anywhere in my loop where it would have been changed). Anyway, I just made sure to get the Id explicitly when I search for the correct Family Symbol. Then it worked just fine.
ctm_mka
my guess would be the break in your for loop was causing tag to be nullified, not sure if you can do this in python, but c# i would use continue vs break for that reason.
