system.nullreference exception object reference
T52K-BIB
T52K-BIB
hi, I'm New to Revit API and learning C# recently and below error comes to whileRun Program.
Anyone can help me.
"system.nullreferenceexception object reference"
using System;
using System.Collections.Generic;
using System.Diagnostics;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
namespace COBie_Door_Space
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
             // Use OfCategory method to apply an ElementCategoryFilter and fine elements in the Doors category
            FilteredElementCollector col = new FilteredElementCollector(doc);
            ICollection<Element> doors = col.OfCategory(BuiltInCategory.OST_Doors).ToElements();
            try
                // Filtered element collector is iterable
                foreach (Element e in doors)
                    FamilyInstance Fi = e as FamilyInstance;
                    Parameter getparam = Fi.LookupParameter("Comments");
                    using (Transaction tx = new Transaction(doc, "getparam"))
                        tx.Start("Parameter Exchange");
                        //set parameter
                        string s = Fi.FromRoom.Name;
                        getparam.Set(s);
                        tx.Commit();
                return Result.Succeeded;
            catch (Exception ex)
                // Code did not execute successfully, display exception error
                TaskDialog.Show("Exception Caught", "Exception: " + ex);
                // return Failed
                return Result.Failed;
RPTHOMAS108
NullReferenceException is the most popular exception by far and a personal favourite of mine.
I assume it is occurring at a location where you’ve declared an object but not given it a value such as:
Your collector has FamilySymbols and FamilyInstances as you’ve not set .WhereElementIsNotElementType. Traditionally this would cause InvalidCastException (my second favourite exception) but with the ‘as’ keyword it masks the problem resulting in a null.
So when you later use a member of Fi you get NullReferenceException.
T52K-BIB
@RPTHOMAS108  Thanks now it's😃 Working!!.
#region Namespaces
using System;
#endregion
          ref string message,
            ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Doors);
            IList <Element> doors = col.WherePasses(filter).WhereElementIsNotElementType().ToElements();
            try
                  Parameter getparam = e.LookupParameter("COBie.Component.Space");
                        //set parameter
                        getparam.Set(s);
                        tx.Commit();
                // return Failed
