System.IO.FileNotFoundException: Could not find file
IrakliA
IrakliA
Hi all,
I am trying to create a panel and attach a tooltip image. However, once I open my Revit file, I the warning that the file cannot be found:
System.IO.FileNotFoundException: Could not find file 'C:\_blog\cbb\res\tooltip\Toottip_Image_320x320.png' File name: 'C:\_blog\cbb\res\tooltip\Toottip_Image_320x320.png'
The code with which I am trying to access the file looks like this:
var TagWallLayersBtnData = new PushButtonData("TagWallLayersBtnData", "Tag Wall\nLayers", Assembly.GetExecutingAssembly().Location, "cbb.TagWallLayersCommand")
ToolTipImage = new BitmapImage(new Uri(@"C:\_blog\cbb\res\tooltip_TagWallLayers_320x320.png")),
ToolTip = "This is some sample tooltip text, replace it later..."
If you have a common experience, how can I solve the issue?
Thanks in advance
IrakliA
The type of the image was .png. However, in addition to that I was including .png in the naming as well (ToolTip_Image.png). The .png in the naming is extra. Thus, while executing code Revit was trying to find a file called ToolTip_image with the extension .png while my files name was ToolTip_Image.png with the extension .png.
All I had to do was to name my file ToolTip_Image (without .png extension) and leave the code as it was (@"file path\ToolTipImage.png)
