Sync To Central pop up not showing up
Tyler.Paolucci6K6QG
Tyler.Paolucci6K6QG
Whenever I sync to central Revit still syncs but the typical pop-up box that shows where the model is in the syncing process has randomly vanished. I have no idea why this changed. Is there an option I changed and how can I fix it?
caroline.gitonga
Hello @Tyler.Paolucci6K6QG,
Sounds like your operations is mainly leaning towards product /end-user support side rather than programmatically implemented.
In that case, kindly note that, you might get more optimal answers to a question like yours relating to product setup, optimisation, usage, and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
You may see below related scenario as yours: https://forums.autodesk.com/t5/revit-api-forum/missing-sync-with-central-progress-pop-up-dialog-box/...
Carol Gitonga, Developer Advocacy and Support, ADN Open
Tyler.Paolucci6K6QG
Tyler.Paolucci6K6QG
Thats funny cause I did read that post before I made a forum post and someone from Autodesk basically said "go to this forum that won't answer your question". I have read both the post you have linked and they do not provide an answer to my problem.
