Suppress FailureMessage on opening of a model
Rockit_for_Revit
Rockit_for_Revit
Is there any method where I can suppress FailureMessages on opening of a model?
I realise there is a method during a transation where the FailureMessage can be Deleted eg:
Dim failMessages As IList(Of FailureMessageAccessor) = failuresAccessor.GetFailureMessages()
For Each fma As FailureMessageAccessor In failMessages
   failure
    If fma.GetFailureDefinitionId = BuiltInFailures.RoomFailures.RoomNotEnclosed Then
        failuresAccessor.DeleteWarning(fma)
Next
However from what I undestand this can only be called during a transation eg:
Using Transaction As New Transaction(e.Document, "Handle Document Opened Failures")
    Dim failOpt As FailureHandlingOptions = Transaction.GetFailureHandlingOptions
    failOpt.SetFailuresPreprocessor(New SuppressRoomFailures)
    Transaction.SetFailureHandlingOptions(failOpt)
    Transaction.Start()
    Transaction.Commit()
End Using
Is there any way the warning can be suppressed without needing a transation e.g. from the DocumentOpened event?
I also need the same from space not enclosed but I can't seem to find SpaceNotEnclosed.
Kind Regards
David
Mohamed_Arshad
HI @Rockit_for_Revit
        If we have a Warning it can be easily resolved. But For error, we don't have a resolution. We need to Subscribe FailuresProcessing Event in IExternalApplication class and implement your failure handling inside that event. This will suppress warnings on file opening. Kindly check the below code for additional reference.
Reference Code
public class RvtApp : IExternalApplication
        public Result OnShutdown(UIControlledApplication application)
            return Result.Succeeded;
        public Result OnStartup(UIControlledApplication application)
            application.ControlledApplication.FailuresProcessing += ControlledApplication_FailuresProcessing;
        private void ControlledApplication_FailuresProcessing(object sender, Autodesk.Revit.DB.Events.FailuresProcessingEventArgs e)
            FailuresAccessor fa = e.GetFailuresAccessor();
            IList<FailureMessageAccessor> failList = new List<FailureMessageAccessor>();
            failList = fa.GetFailureMessages(); // Inside event handler, get all warnings
            foreach (FailureMessageAccessor failure in failList)
                if (fa.GetSeverity()==FailureSeverity.Warning)
                    fa.DeleteWarning(failure);
            e.SetProcessingResult(FailureProcessingResult.Continue);
Note:  The source code is on C# , Please convert it to VB.
Additional Reference on Failure Handling: https://spiderinnet.typepad.com/blog/2011/02/implement-a-revit-failuresprocessing-event-handler-with...
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Rockit_for_Revit
Perfect thank you
