Suitable Grasshopper Scripts
eizinmyat
eizinmyat
Hello everyone,
Good evening!!
I would like to ask you about Grasshopper scripts in Rhino Inside Revit. Is there any grasshopper scripts that I could change the calculation from addition to subtraction and on the other hand from subtraction to addition automatically based on the number that I inserted in the panel.
For example, I insert +1500 in the panel and  calculation calculated in the picture that I have attached below. Oppositely, if I insert -1500 and I want my calculation process changed opposite from addition to subtraction. If you all have any suitable scripts, could you explain it to me?
Thank you all.
Have a nice day, everyone!!
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
msgambelluri
The x+y are hardcoded components.
Consider using the expression component
Here is a sample to help you get started.
Marcello Sgambelluri
