StructuralFramingUtils
Ryan
Ryan
This is probably very simple, but im probably just to new the api to figure it out.
Im trying to select framing element(s) in revit, and running the structuralframingutlis.DisallowJoinAtEnd command to mass dissallow framing joins on all selected objects.
I dont have much code to post because im stuck right from the start.
I can get selected objects elemntid's, but i dont know how to turn that infomation in to family instances, which what the   StructuralFramingUtils
wants.
Am i starting in the wrong place? Im not even sure of the proper syntax for   StructuralFramingUtils.
Thanks!
           // Get the element selection of current document.
            Selection selection = uidoc.Selection;
            ICollection<ElementId> selectedIds = uidoc.Selection.GetElementIds();
You can loop through the selection and get each element with
 Element e = doc.GetElement(elementid);
And then filter on it's category.
You can also search a document for all it's structural elements without letting the user select elements like :
        FilteredElementCollector structuralCollection = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_StructuralFraming);
Hope this helps,
Oh yeah, one other thing. DisallowJoinAtEnd only works in Revit 2015
Ryan
Thanks R.van,
I am working in 2015. Mainly for that function.
That's pretty much what i have been trying, but when i try to pass in the ids into GetElement, I get an error saying
cannot convert from 'System.Collections.Generic.ICollection<Autodesk.Revit.DB.ElementId>' to 'Autodesk.Revit.DB.ElementId' (CS1503)
            UIDocument uidoc = this.ActiveUIDocument;
            Document doc = uidoc.Document;
            ICollection<ElementId> elementId = uidoc.Selection.GetElementIds();
            Element e = doc.GetElement(elementId);
And Revit is right, you are putting an ICollection of elementIds in a function that expects one single elementId.
Try something like this:
List<Element> myelements = new List<Element>
foreach (elementid elid in uidoc.Selection.GetElementIds())
    myelements.add(doc.GetElement(elid));
Ryan
Thanks again R.Van,
Got it working.
To take it one step further, how would i pass the selected elements through a filter so that it will only send the framing elements to the StructUtils command. So i wont have to manually filter the elements.
I tried with the filtered elements collector, that's really the only way i know how to filter elements.
But i have a feeling there is another way to go about it.
            List<Element> myElements = new List<Element>();
              foreach (ElementId elid in uidoc.Selection.GetElementIds())
//Not sure how to apply a filter to the elements so that it will only pass through structural framing elements.
                  FilteredElementCollector collector = new FilteredElementCollector(doc);
                collector.OfCategory(BuiltInCategory.OST_StructuralFramingOther);
var query = from element in collector
    where element.Equals(myElements)
    select element;*/
                myElements.Add(doc.GetElement(elid));
Okay, that would be something like this :
    Element elem = doc.GetElement(elid);
    if(el.category.name.Contains("structural") myelements.add(elem);
// or .Equal("Structural framing")
