start external program
I'm starting to learn Revit AIP, but while I'm doing lesson1 there is an error "There was a mismatch between the processor architecture of the project being built "MSIL" and the processor architecture of the reference "RevitAPIUI", "AMD64".
and I got a solution to change platform target from Any CPU to x64. however when i click start, it doesnt  start external program which is" C:\Program Files\Autodesk\Revit 2018\Revit.exe". im using student version Revit 2018 and 2017 visual studio.  it show up like the pic but they are just gone.fgsdfh.png
jeremytammik
Welcome to the Revit API!
Glad to have you here.
The message you mention is not an error, just a warning.
You can ignore it.
Personally, I prefer zero warnings, so I implemented a little utility to fix that:
http://thebuildingcoder.typepad.com/blog/2013/07/recursively-disable-architecture-mismatch-warning.h...
https://github.com/jeremytammik/DisableMismatchWarning
Please work through the getting started material before asking any further questions:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Thank you!
Good luck and lots of fun getting started with the Revit API.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
