Start extension, End extension
how to change Start extension, End extension of steel member through API.
Appreciate your help.
-RK
jeremytammik
Find out for yourself:
  • Install RevitLookup.
  • Explore the element properties.
  • Manually change the start and end extension.
  • Note the differences.
Once you have determined what modifications were made in the Revit database by the manual manipulation, you can easily reproduce the same programmatically via API.
Here are some other, more detailed explanations of various tools and processes you can use to dig in deeper, if you like:
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
