Stair Support Parameter Binding
csds360
csds360
Hi
I wanted to see if anybody could shed some light on this.
I have been having a problem with parameter binding to a particular category through the API. This is the 'Support' category that is a child of 'Stairs'.
Through the UI, this simply is done by checking this box:
When you get the category from the element in Revit via RevitLookup it returns:
Category of BuiltInCategory.OST_StairsStringerCarriage with .AllowsBoundParameters = True
When you get the category via
Category.GetCategory(Doc, BuiltInCategory.OST_StairsStringerCarriage) it returns:
Category of BuiltInCategory.OST_StairsSupports with .AllowBoundParameters = False
This is preventing attaching parameters to the element via the API (as can be done in the UI).
Does anybody know if there is a way round this, or is this in the API by design or possibly a bug?
Any help would be greatly appreciated?
Many thanks.
@Anonymous @naveen.kumar.t@RPTHOMAS108
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @csds360 ,
The development team is aware of this issue and they are working on it.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
csds360
Hi @naveen.kumar.t
Many thanks for your prompt response and clarification.
dev
Just a remark - I am also encountering this issue for my company's Revit plug-in.
aignatovich
Hi guys. Yes, I understand this is an old post, but this issue also affects the latest Revit 2022 version.
So the workaround could be something like this:
var col = FilteredElementCollector(doc);
var filter = new LogicalAndFilter(new ElementCategoryFilter(BuiltInCategory.OST_StairsStringerCarriage), new ElementIsElementTypeFilter());
var element = col.WherePasses(filter).FirstElement(); // At least one type exists even in empty model. Revit prevents deletion of the last element type of this category
var category = element.Category; // correct OST_StairsStringerCarriage category
csds360
Thank you @aignatovich. That did the trick.
