Stacktrace question
Stacktrace question
jw.vanasselt
Stacktrace question
jw.vanasselt
Hi all,
I try to use the stacktrace of my revit scripts.
In this case I try to create a sheet with a number that already exist.
I want to retrieve the data from my stacktrace, for example the line of my script where this script goes wrong.
In this case "Line 30".
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System;
using System.Diagnostics;
using static VDS.VDS_standaard_definities;
namespace VDS
    [Transaction(TransactionMode.Manual)]
    public class StackTraceVDS : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            //UIApplicatin, uidoc, doc
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            using (Transaction tx = new Transaction(doc, "Test"))
                try
                    tx.Start();
                    VDS_Sheets vDS_Sheets = new VDS_Sheets();
                    Element tBlock = vDS_Sheets.VDS_GetTitleBlockByName(doc, "A3 Landschap");
                    ViewSheet sheet = ViewSheet.Create(doc, tBlock.Id);
                    sheet.SheetNumber = "L-00";
                    tx.Commit();
                catch (Exception ex)
                    StackTrace stackTrace = new StackTrace(ex, true);
                    StackFrame stackFrame = stackTrace.GetFrame(0);
                    var fileName = stackFrame.GetFileName();
                    var method = stackFrame.GetMethod();
                    var number = stackFrame.GetFileLineNumber();
                    Debug.Print($"Filenaam: {fileName}");
                    Debug.Print($"Method: {method}");
                    Debug.Print($"number: {number}");
            return Result.Succeeded;
This is what I retrieve in my debug:
Filenaam:
Method: Void set_SheetNumber(System.String)
number: 0
Any thoughts?
KG,
Jan Willem
jeremy_tammik
Run Revit.exe inside the Visual Studio debugger and load your add-in inside that context. Then you can examine the stack at any time.
ricaun
Probably you are not copying the Program Debug Database (.pdb) file with your Assembly (.dll). Without that, the Exception is not gonna show any debug information about the file, line, etc.
A simple test is to divide an integer by zero.
try
    int a = 0;
    int b = 1 / a;
    Debug.Print($"Exception: {ex}");
    Debug.Print($"FileName: {fileName}");
    Debug.Print($"Number: {number}");
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
jeremy_tammik
By the way, if you are looking for more tracing options than you would have believed exist, here is a neat place to start:
jw.vanasselt
Thanks @jeremy_tammik and @ricaun , this works.
And nice topic about tracing!
