spot coordinate value
aliobidi
aliobidi
Hi folks ..
I'm trying to get spot coordinate value from the roof corners and fill all of them on schedule or Excel sheet  like the image
what is the easiest way for this
thanks
jeremy_tammik
Here is a possible solution:
aliobidi
Thanks you
But is there any script that can read all spot coordinat on the project Serially (first spot add in the project to last one )
And fill them in Schedule  (first spot add in the project to last one )
Sorry but I'm Fusion 360 user and using API for it but in revit and dynamo With difficulty
Any hints how can I think or any kind of help will appreciate
ctm_mka
First, i do not believe which element is placed first is tracked, you would have to add that manually to the spot elevation, perhaps as one of the instance parameter suffixes. Second, for actually doing what you want, here's the workflow i would use:
  1. Grab all Spot Coordinate elements in the Active View.
  2. Loop through each spot coordinate and pull the number (whatever parameter you have that assigned to) and the Origin property into a list with appropriate properties for each parameter (number, North, East & Elevation),
  3. Sort the list by number.
  4. export to csv.
Please remember, we are here to help you develop your application, but not to write it for you.
