Split Button problem
I am trying to make a split button exactly like in Revit.
For Exemple Slab in "Structure"
As you can see the label is different from the first choice.
When I am creating my own splitButton with this code (I create from a custom model)
var splitButtonData = new SplitButtonData(dropDownButton.Name, dropDownButton.Name);
var splitButton = ribbonPanel.AddItem(splitButtonData) as SplitButton;
if (splitButton != null)
	splitButton.IsSynchronizedWithCurrentItem = false;
foreach (var pushButtonContent in dropDownButton)
	var button = new PushButtonData(
		pushButtonContent.CommandType.Name,
		pushButtonContent.Text,
		pushButtonContent.CommandType.Assembly.Location,
		pushButtonContent.CommandType.FullName);
		if (pushButtonContent.LargeImage != null)
			button.LargeImage = BitmapToImageSourceConverter.Convert(pushButtonContent.LargeImage);
		if (!string.IsNullOrEmpty(pushButtonContent.AvailabilityClassName))
			button.AvailabilityClassName = pushButtonContent.AvailabilityClassName;
	splitButton?.AddPushButton(button);
Basically, dropDownButton.Name is "Form Deck", but
I get this
I don't want the top button and description to be linked to first item.
Also if possible I would like the top button to be independent and have it own command handler based on a algorithm to chose the best option base on the selection in Revit.
Thank you for helping me.
Charles
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
The Ribbon SplitButton is designed to show the text and image of the current button, as what says in SplitButtonData: " This text will be displayed on the button if drop-down is empty. If sub-items are added,  then the split button will display the current PushButton's text.". You can try PulldownButton instead if possible.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
PulldownButton is not what I need. I need a top button and a pull down menu under. How can Revit achieve this behavior? Do you guys have special control in your toolkit not accessible to other developers?
I answered myself. If anyone is wondering how to do  a split button like in Revit, you must use Autodesk.Windows.RibbonSplitButton instead.
Then use
ShowText = true;
IsSplit = true;
Size = Autodesk.Windows.RibbonItemSize.Large;
The binding of the command is different, but you guys can handle this part.
Hope that help anyone,
Charles
ekouassi
Can you add the lines of code please?
Thanks!.
