Sort Plumbing Fixture list such as System Browser
reylorente1
reylorente1
I would like to the list of Plumbing Fixture, as it appears in the System Browse
Quisiera ordenar la lista de mueble sanitario, tal como aparece en el System Browser
2021-03-07 (2).png Here is the script
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Aplicación app = uiapp.Application;
Document doc = uidoc.Document;
string nombre_mueble = string.Empty;
//Extract all pipe system
foreach (PipingSystem pipingSystem in new FilteredElementCollector(doc)
.OfClass(typeof(PipingSystem)).WhereElementIsNotElementType().ToList())
// Get the Domestic Cold Water type
if (pipingSystem.SystemType == PipeSystemType.DomesticColdWater)
var elemset = pipingSystem.PipingNetwork;
foreach (Element elem in elemset)
FamilyInstance fi;
if (elem is FamilyInstance)
fi = elem as FamilyInstance;
if (fi != null)
MEPModel mEPModel = fi.MEPModel;
if (mEPModel is MechanicalFitting)
MechanicalFitting mf = mEPModel as MechanicalFitting;
if (fi.Category.Id == new Elemento(BuiltInCategory.OST_PipeFitting))
if (fi.Category.Id == new ElementId(BuiltInCategory.OST_PlumbingFixtures))
IList<Connector> connectorse = GetConnectors(fi);
foreach (var connector in connectorse)
if (connector.PipeSystemType == PipeSystemType.DomesticColdWater)
// var mepConnectorInfo = connector.GetMEPConnectorInfo() as MEPFamilyConnectorInfo;
// var parameterValue = (DoubleParameterValue)mepConnectorInfo.GetConnectorParameterValue(new ElementId(BuiltInParameter.CONNECTOR_DIAMETER));
// diametro_mueble = UnitUtils.ConvertFromInternalUnits(parameterValue. Value, UnitTypeId.Millimeters).ToString();
nombre_mueble += connector.Owner.Name + "\n"; //This is where I find the names
// demanda_m = connector.Demand.ToString();//Demanda del mueble
TaskDialog.Show("Revit_Informacion", nombre_mueble);
return Result.Succeeded;
#region Recuperar conectores de FamilyInstance
static IList<Connector> GetConnectors(FamilyInstance inst)
//1. Cast Element to FamilyInstance
//FamilyInstance inst = element as FamilyInstance;
//2. Get MEPModel Property
MEPModel mepModel = inst.MEPModel;
//3. Get connector set of inst
ConnectorSet connectorSet = mepModel.ConnectorManager.Connectors;
//4. Initialise empty list of connectors
List<Connector> connectorList = new List<Connector>();
//5. Loop through connector set and add to list
foreach (Connector connector in connectorSet)
connectorList.Add(connector);
return connectorList;
#endregion
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @reylorente1,
I am not aware of any such API.
Have a look at this below link
https://forums.autodesk.com/t5/revit-api-forum/filteredelementcollector-or-elementset-order-by-close...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jeremy_tammik
reylorente1
Gracias!!
Thank You!!
Спасибо!!
