Some issues after comparing Revit 2015 and 2017
nitinjambhale
nitinjambhale
Hi All,
1) Please view attached image.
2) In that structure when i placed coupling generic on branch pipe, i am getting modified elements count as 4 in Updater (_data.GetModifiedElementIds())     with Revit 2015 API and same scenario when i place coupling generic in Revit 2017, i am getting modified elements count as 2 (which is i am expecting     and its perfect in this scenario.)
    Now what is Updater : Updater is the class inheriting interface  IUpdater, which is use to track revit document changes with API.
3) Now with those 2 extra elements i am getting in list is creating a huge problem for me in 2015.
4) So, may wait for another update of Revit 2015 (currently i am Update Release 14) to fix this bug.
Please have a look into this.
Thank You.
Nitin J.
jeremytammik
Dear Nitin,
Thank you for your query.
There is no guarantee that the updater will return the same number of elements every time.
I suggest that you revisit your code and implement a check so that only the elements that really are of interest to you are processed in the manner you intend.
I do not believe that anybody can provide any guarantee or expectation whatsoever of publishing further updates for Revit 2015.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
