Some annotations, schedules, view templates, filters, and views related to analytical elements might be modified or lost during the upgrade process
jacopo_chiappetti
Message 1 of 16
jacopo_chiappetti
in Revit 2023, every time I open a model that contains at least one analytical element, a warning will be displayed at the end of the upgrade process: "Some annotations, schedules, view templates, filters, and views related to analytical elements might be modified or lost during the upgrade process."
this error window doesn't seem to be trappable by code (ie. Application_FailuresProcessing) and blocks the automatic process of the model (custom code) , after it is opened, until it's closed by the user
Is there a way to eliminate the message or intercept it somehow?
ref: https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-E74EC52F-EFC6-4914-84B8-0119002A1C98
Replies (15)
Message 2 of 16
jeremy_tammik
Yes, definitely. If worst comes to worst, you can use the native Windows API to catch and dismiss this dialogue. Look at the various options listed in The Building Coder topic group on detecting and handling dialogues and failures:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.32
Message 3 of 16
jacopo_chiappetti
thanks for the fast reply
I cannot use Application.FailuresProcessing because this event doesn't trap this warning
also cannot use ControlledApplication.DialogBoxShowing as I use IExternalDBApplication not IExternalApplication
so the only way seems using your JtClicker , isn't it? or there is another solution that I haven't found?
Message 4 of 16
jeremy_tammik
Those are the three possibilities that I am aware of...
Message 5 of 16
jacopo_chiappetti
I gave to the "Greg" solution here https://thebuildingcoder.typepad.com/blog/2009/10/dismiss-dialogue-using-windows-api.html a try and it works with some small mods
loading process is slower but finally I can trap warning dialog and close it
I really can't understand why this warning hasn't been included, along with all the others, in the Application.FailuresProcessing event or is not given the possibility to disable it: really disheartening
thanks again
Message 6 of 16
jeremy_tammik
Congratulations on solving it and thank you for letting us know. Maybe it is an oversight. I asked the development team for you.
Message 7 of 16
jacopo_chiappetti
since the dialogbox does not contemplate any action, as for the other warnings, the best solution could be to add a property of OpenOptions, something like oo.IgnoreAnalyticalElements, to open document
Message 8 of 16
jeremy_tammik
The development team replied:
You should respond to the DialogBoxShowing event callbacks and overrides, I think. It's not actually a document "failure" which is why it doesn't work with FailuresProcessing.
Didn't you say that you tried that?
Message 9 of 16
jacopo_chiappetti
as I said I cannot use ControlledApplication.DialogBoxShowing as I use (Implements) IExternalDBApplication, not IExternalApplication
I know  it's not a document "failure" , for this reason I proposed to add a property of OpenOptions, something like oo.IgnoreAnalyticalElements, to open document: that way works even without UI
Message 10 of 16
jeremy_tammik
Ah yes, of course, so you said. That makes perfect sense. Well, I'm glad that the native API solution works. I have pointed out this hole in the API to the development team.
Message 11 of 16
jeremy_tammik
Their opinion also makes sense: If they are operating in an interactive session of Revit they should be able to use IExternalApplication.   I expect they may be trying to keep their code split validly between DB and UI levels (which is great; it allows the DB code to work with Design Automation API), so they might need a specific small UI Application subscribing to and dismissing just this notice.
Is that feasible for you? Or is the JtClicker approach easier? Would you care to share your JtClicker implementation, in case other have need for it as well? Thank you!
Message 12 of 16
jacopo_chiappetti
for many reasons I prefer to don't use UI so it's easier to use the "JtClicker approach"
I post my implementation but it's very similar to the "Greg" version
    Public timer1 As Timer
    Public timer_interval As Integer = 1000  'millisecondi
    Public timer_attempts As Integer 'not used
    Public Const diagTitle As String = "Aggiornamento del modello analitico strutturale"
    Public Const diagButton As String = "&Chiudi"
   Public Function EnumWindowsProc(ByVal hwnd As Integer, ByVal lParam As Integer) As Boolean
        Dim sbTitle As New StringBuilder(256)
        Dim test As Integer = User32.GetWindowText(hwnd, sbTitle, sbTitle.Capacity)
        Dim title As String = sbTitle.ToString()
        If title.Length > 0 AndAlso title = diagTitle Then
            User32.EnumChildWindows(hwnd, New User32.EnumWindowsProc(AddressOf EnumChildProc), 0)
            Return False
        Else
            Return True
    End Function
    Public Function EnumChildProc(ByVal hwnd As Integer, ByVal lParam As Integer) As Boolean
        If title.Length > 0 AndAlso title = diagButton Then
            User32.SendMessage(hwnd, User32.BM_SETSTATE, 1, 0)
            User32.SendMessage(hwnd, User32.WM_LBUTTONDOWN, 0, 0)
            User32.SendMessage(hwnd, User32.WM_LBUTTONUP, 0, 0)
            If Not timer1 Is Nothing Then
                timer1.Stop()
                timer1 = Nothing
            Return False
        Else
            Return True
    End Function
    Public Sub timer1_Elapsed(ByVal sender As Object, ByVal e As EventArgs)
        'If timer_attempts < 3000 Then
        User32.EnumWindows(New User32.EnumWindowsProc(AddressOf EnumWindowsProc), 0)
        'Else
        '    timer1.Stop()
        'End If
        'timer_attempts += 1
        'Debug.Print(timer_attempts.ToString())
    End Sub
    Public Sub closeOptionsDialog()
        timer_attempts = 0
        If timer1 Is Nothing Then
            timer1 = New Timer()
        timer1.Interval = timer_interval
        AddHandler timer1.Elapsed, New ElapsedEventHandler(AddressOf timer1_Elapsed)
        timer1.Start()
    End Sub
user32 module is the same
Imports System
Imports System.Runtime.InteropServices
Imports System.Text
Module User32
    Delegate Function EnumWindowsProc(ByVal hWnd As Integer, ByVal lParam As Integer) As Boolean
    <DllImport("user32.dll", CharSet:=CharSet.Unicode)>
    Function FindWindow(ByVal className As String, ByVal windowName As String) As Integer
    End Function
    Function EnumWindows(ByVal callbackFunc As EnumWindowsProc, ByVal lParam As Integer) As Integer
    End Function
    Function EnumChildWindows(ByVal hwnd As Integer, ByVal callbackFunc As EnumWindowsProc, ByVal lParam As Integer) As Integer
    End Function
    Function GetWindowText(ByVal hwnd As Integer, ByVal buff As StringBuilder, ByVal maxCount As Integer) As Integer
    End Function
    Function GetLastActivePopup(ByVal hwnd As Integer) As Integer
    End Function
    Function SendMessage(ByVal hwnd As Integer, ByVal Msg As Integer, ByVal wParam As Integer, ByVal lParam As Integer) As Integer
    End Function
    Public BM_SETSTATE As Integer = 243
    Public WM_LBUTTONDOWN As Integer = 513
    Public WM_LBUTTONUP As Integer = 514
End Module
Message 13 of 16
jeremy_tammik
Thank you for sharing and for your interesting point of view!
Message 14 of 16
Kev_D
Is there a non API solution to remove this?
Message 15 of 16
jeremy_tammik
I doubt it. Well, there are Windows utilities that you can use, of course. Standard Windows automation. They can click buttons for you, i.e., simulate the user interaction:
https://duckduckgo.com/?q=windows+automation+tool
Message 16 of 16
jeremy_tammik
Shared on the blog for better searching and finding (for me) and posterity:
https://thebuildingcoder.typepad.com/blog/2023/02/geometry-options-and-clean-simple-curves.html#4
