Solid sketched stair is broken halfway
Hi everybody,
I was trying to create this fancy stair in Revit using Stair/ Create by Sketch. It was all fun and right with assembled stair until I changed the type to any solid stairs: Monolithic or precast. It got broken just like the screenshot. I tried to adjust the parameters but none did work.
Did this happen to any of you? I attach the revit file in 2016 version for your reference.
recepagah12
I guess your question is about Revit User Interface. This forum is only for Revit API ( Application Programming Interface) related questions. You can use Revit Architecture forum this question. Also, I am sure people in there have many experience in like this situation.
I hope this helps,
Recep.
Hi there, thanks for the suggestion. Is there a way to move this post over there or I just post it again?
Thanks.
recepagah12
As I know, only moderators can move the post. I think you should create a new post.
Good Luck, by the way, finding a satisfying answer.
Recep.
