SlabShapVertexArray don't work for me
In one of my plugin i would like to move floor vertex height, so I used this line :
SlabShapeVertexArray slabShapeVertexArray = floor.SlabShapeEditor.SlabShapeVertices;
in order to get the vertex array and I used a "for" loop to get each vertex :
             for (int i = 0; i < slabShapeVertexArray.Size; ++i)
                SlabShapVertex vertex = slabShapeVertexArray.get_Item(i);
but i never goes in the loop, so I i check the value of slabShapeVertexArray.Size and it's equal to 0;
Can someone help me Because i Don't know why i can't get the vertices
RPTHOMAS108
Did you call SlabShapeEditor.Enable?
Note that you can't use this on a slab with a slope set by sketch.
No, i didn't call this method, but i've tried and it Don't change anything, the size field is still equal to 0.
I already use the slabShapEditor.drawPoint and it works, but the SlabShapVertexArray does not contain any Vertex
RPTHOMAS108
Yeah I see why.
You have to call Document.Regenerate if you are Enabling a slab not already enabled and manipulating the SubElements in the same transaction.
Private Function TObj137(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        If commandData.Application.ActiveUIDocument Is Nothing Then Return Result.Cancelled Else
        Dim UIDoc As UIDocument = commandData.Application.ActiveUIDocument
        Dim IntDoc As Document = commandData.Application.ActiveUIDocument.Document
        Dim AcView As View = UIDoc.ActiveGraphicalView
        Dim R1 As Reference = Nothing
        Try
            R1 = UIDoc.Selection.PickObject(Selection.ObjectType.Element)
        Catch ex As Exception
        End Try
        If R1 Is Nothing Then Return Result.Cancelled Else
        Dim El As Floor = TryCast(IntDoc.GetElement(R1), Floor)
        If El Is Nothing Then Return Result.Cancelled Else
        Using tx As New Transaction(IntDoc, "Edit slab")
            If tx.Start = TransactionStatus.Started Then
                If El.SlabShapeEditor Is Nothing Then
                    tx.RollBack()
                If El.SlabShapeEditor.IsEnabled = False Then
                    El.SlabShapeEditor.Enable()
                If El.SlabShapeEditor.SlabShapeVertices.Size = 0 Then
                    IntDoc.Regenerate()
                For I = 0 To El.SlabShapeEditor.SlabShapeVertices.Size - 1
                    Dim Vx As SlabShapeVertex = El.SlabShapeEditor.SlabShapeVertices(I)
                    If I = 1 Then
                        El.SlabShapeEditor.ModifySubElement(Vx, 0.5)
                Next
                tx.Commit()
        End Using
        Return Result.Succeeded
    End Function
josborneW959Y
You have to do a couple things...
SlabShapeEditor editor = floor.GetSlabShapeEditor();
editor.Enable();
doc.Regenerate();
After regenerate editor.SlabShapeVertices will return Vertex. A little bit crazy in my opinion...
