Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
In one of my plugin i would like to move floor vertex height, so I used this line :
SlabShapeVertexArray slabShapeVertexArray = floor.SlabShapeEditor.SlabShapeVertices;
in order to get the vertex array and I used a "for" loop to get each vertex :
for (int i = 0; i < slabShapeVertexArray.Size; ++i)
SlabShapVertex vertex = slabShapeVertexArray.get_Item(i);
but i never goes in the loop, so I i check the value of slabShapeVertexArray.Size and it's equal to 0;
Can someone help me Because i Don't know why i can't get the vertices
No, i didn't call this method, but i've tried and it Don't change anything, the size field is still equal to 0.
I already use the slabShapEditor.drawPoint and it works, but the SlabShapVertexArray does not contain any Vertex
Yeah I see why.
You have to call Document.Regenerate if you are Enabling a slab not already enabled and manipulating the SubElements in the same transaction.
Private Function TObj137(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
If commandData.Application.ActiveUIDocument Is Nothing Then Return Result.Cancelled Else
Dim UIDoc As UIDocument = commandData.Application.ActiveUIDocument
Dim IntDoc As Document = commandData.Application.ActiveUIDocument.Document
Dim AcView As View = UIDoc.ActiveGraphicalView
Dim R1 As Reference = Nothing
Try
R1 = UIDoc.Selection.PickObject(Selection.ObjectType.Element)
Catch ex As Exception
End Try
If R1 Is Nothing Then Return Result.Cancelled Else
Dim El As Floor = TryCast(IntDoc.GetElement(R1), Floor)
If El Is Nothing Then Return Result.Cancelled Else
Using tx As New Transaction(IntDoc, "Edit slab")
If tx.Start = TransactionStatus.Started Then
If El.SlabShapeEditor Is Nothing Then
tx.RollBack()
End If
If El.SlabShapeEditor.IsEnabled = False Then
El.SlabShapeEditor.Enable()
End If
If El.SlabShapeEditor.SlabShapeVertices.Size = 0 Then
IntDoc.Regenerate()
End If
For I = 0 To El.SlabShapeEditor.SlabShapeVertices.Size - 1
Dim Vx As SlabShapeVertex = El.SlabShapeEditor.SlabShapeVertices(I)
If I = 1 Then
El.SlabShapeEditor.ModifySubElement(Vx, 0.5)
End If
Next
tx.Commit()
End If
End Using
Return Result.Succeeded
End Function
