Show hidden lines in DXF Export by code
Hello
I can export active view to dxf file without any problem. but I want to see hidden lines (the lines that underneath other elements) with dashed line style in this dxf export. How can we do that in API and C#?
Please see attached PDFs for more information.
jeremytammik
How can you do achieve that manually in the user interface? Solve that first, before looking at the programming side of things.
Jeremy Tammik
Developer Technical Services
The Building Coder
the solution is in pdf files. please check them.
I have found the solution. I paste it here for other developers
doc.ActiveView.get_Parameter(BuiltInParameter.MODEL_GRAPHICS_STYLE).Set((int)DisplayStyle.HLR);
doc.ActiveView.get_Parameter(BuiltInParameter.VIEW_SHOW_HIDDEN_LINES).Set((int)ShowHiddenLinesValues.All);
doc.ActiveView.get_Parameter(BuiltInParameter.VIEW_DISCIPLINE).Set((int)ViewDiscipline.Mechanical);
