SharpDevelop Forms Designer not working in Revit 2021
sragan
Message 1 of 25
sragan
In Revit 2020, I can create a new C# module, create a new C# Macro, go to Project, Add New Item, and add a WPF C# Window which is named Window1.
If I then select the Window1 I can view the code.  Clicking the "Design" tab at the bottom of the code window shows a preview of the window.
In Revit 2021, I get no preview.  Just an error message:
System.NullReferenceException: Object reference not set to an instance of an object.
at ICSharpCode.FormsDesigner.Services.TypeResolutionService..ctor()
at ICSharpCode.WpfDesign.AddIn.MyTypeFinder..ctor()
at ICSharpCode.WpfDesign.AddIn.MyTypeFinder.Create(OpenedFile file)
at ICSharpCode.WpfDesign.AddIn.WpfViewContent.LoadInternal(OpenedFile file, Stream stream)
at ICSharpCode.SharpDevelop.Gui.AbstractViewContentHandlingLoadErrors.Load(OpenedFile file, Stream stream)
Is there any fix?
Replies (24)
Message 21 of 25
Organon
@H.echeva,
It works for me, but you have to do it every time you open Revit.
This problem only occurs from version 2021, so you can use version 2019/2020.
Arquitectura | Análisis CAD & BIM | Diseño Paramétrico | Programación
BIM-METADATA | LinkedIn | YouTube
Message 22 of 25
H.echeva
Well, I think I found another (radical) solution.
I have copied the content of the folder SDA from 2018 to the folder in 2022.
The form works! I hope I haven't broken anything. I have kept a backup just in case.
Message 23 of 25
Organon
@H.echeva,
That was a risky move. 😃👍
Message 24 of 25
sragan
Oddly enough, the Forms Designer works again on a fresh install of Revit 2024.
Strange.
Message 25 of 25
rbustos
I found a possible solution:
copy the SDA from Revit 2019 to Revit 2023
