Shared parameter as Project parameter
I have tried two methods using Dynamo to create a project parameter:
- By adding new shared parameters only bound to the category "Project Information" with the custom node below.
- By using the node "Create Project parameter".
In both cases the project parameter is available, but the binding with for instance a title block containing the same shared parameter is not working. As if the parameter has a GUID mismatch, but they both come from the same external shared parameter file.
Is there anything I'm missing? The active shared parameter file is correct, and the specific parameters have been added to the title block family. Any of the added project parameters can not be edited in the sheet's title block.
For the first option I'm using a modified version of Konrad's solution to create shared parameters. This one can handle multiple categories.
#Copyright(c) 2015, Konrad Sobon
# @arch_laboratory, http://archi-lab.net
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
# Import DocumentManager and TransactionManager
clr.AddReference("RevitServices")
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
# Import RevitAPI
clr.AddReference("RevitAPI")
import Autodesk
from Autodesk.Revit.DB import *
doc = DocumentManager.Instance.CurrentDBDocument
uiapp = DocumentManager.Instance.CurrentUIApplication
app = uiapp.Application
from System.Collections.Generic import *
# Import ToDSType(bool) extension method
clr.AddReference("RevitNodes")
import Revit
clr.ImportExtensions(Revit.Elements)
import System
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
_paramName = IN[0]
_groupName = IN[1]
_paramType = IN[2]
_visible = IN[3]
_category = IN[4]
_paramGroup = IN[5]
_instance = IN[6]
def ParamBindingExists(_doc, _paramName, _paramType):
	map = doc.ParameterBindings
	iterator = map.ForwardIterator()
	iterator.Reset()
	while iterator.MoveNext():
		if iterator.Key != None and iterator.Key.Name == _paramName and iterator.Key.ParameterType == _paramType:
			paramExists = True
			break
		else:
			paramExists = False
	return paramExists
def RemoveParamBinding(_doc, _paramName, _paramType):
	iterator.Reset()
			definition = iterator.Key
			break
	message = None
	if definition != None:
		map.Remove(definition)
		message = "Success"
	return message
def addParam(doc, _paramName, _visible, _instance, _groupName, _paramGroup,k):
	message = None
	if ParamBindingExists(doc, _paramName, _paramType):
		if not RemoveParamBinding(doc, _paramName, _paramType) == "Success":
			message = "Param Binding Not Removed Successfully"
		else:
			message = None
	group = file.Groups.get_Item(_groupName)
	if group == None:
		group = file.Groups.Create(_groupName)
	if group.Definitions.Contains(group.Definitions.Item[_paramName]):
		_def = group.Definitions.Item[_paramName]
	else:
   		_def = group.Definitions.Create(opt)
	param = doc.ParameterBindings.Insert(_def, bind, _paramGroup)
	return message
#"Start" the transaction
TransactionManager.Instance.EnsureInTransaction(doc)
try:
	file = app.OpenSharedParameterFile()
except:
	message = "No Shared Parameter file found."
	pass
k=0
while k<_paramName.Count:
	cats = app.Create.NewCategorySet()
	# Insert each category instead of one here...
	for CaT in _category[k]:
		builtInCategory = System.Enum.ToObject(BuiltInCategory, CaT.Id)
		cats.Insert(doc.Settings.Categories.get_Item(builtInCategory))
	if _instance[k]:
		bind = app.Create.NewInstanceBinding(cats)
	else:
		bind = app.Create.NewTypeBinding(cats)
	opt = ExternalDefinitionCreationOptions(_paramName[k], _paramType[k])
	opt.Visible = _visible[k]
	if isinstance(_paramName[k], list):
		for i in _paramName[k]:
			message = addParam(doc, i, _visible[k], _instance[k], _groupName[k], _paramGroup[k], k)
	else:
		message = addParam(doc, _paramName[k], _visible[k], _instance[k], _groupName[k], _paramGroup[k],k)
	k=k+1
# "End" the transaction
TransactionManager.Instance.TransactionTaskDone()
	#Assign your output to the OUT variable
if message == None:
	OUT = "Success"
else:
	OUT = message
jeremytammik
Afaik Revit API does not support creation of project parameters.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
bchaney0927
I would like to be able to add project parameters to my projects.  One example is being able to add a list of consultants with roles and contact information.  Is there a way to do this, or do I need to make a new title block for every project?
Bennett
Bennett Chaney, AIA
http://bscarchdesphot.com
scheerd
Check out Extensible Storage.  Not as easy as SPs, but that's the only way I know of saving information to a project at the top level.  Very flexible, and can store lots of data in lots of formats.
jeremytammik
Check out the collection on articles on extensible storage here:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.23
Especially this one one global storage:
https://thebuildingcoder.typepad.com/blog/2016/04/named-guid-storage-for-project-identification.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
axelrasmussen
Did someone find a solution to this problem? I think it should be possible now in the newest versions of Revit/Dynamo, right?
I'm having the same Issue (probably GUID mismatch) 😕
axelrasmussen
Okay, the problem was that there were two Projectparameters with a similar Name "GFZ" and GFZ Test". I was trying to set "GFZ" but I assume that the setParameter-Node was taking "GFZ Test"...
I deleted "GFZ Test" from the sharedParameter.txt and it worked 🙂
